Throttle Cable Inner Wire Removal
Posted: Mon Jul 17, 2017 8:14 am
If I remove the inner part of the hand operated throttle cable (orig. metal T handle variety with "ratchet" lock) will the mechanism inside come apart?
The reason I ask is I'd like to remove the guts for a cleaning and to deal with any kinks that have accumulated over the years. The ratchet sounds like it's spring loaded and I figured I'd see if anyone has pulled one apart before I manage to break the thing while trying to "fix" it! It works now, it's just pretty sticky.
