1954 Cdn M152, M37, M43 Parts For Sale
Posted: Mon Jul 10, 2017 12:39 pm
All parts in Phoenix, Arizona 85018 Prefer local pickup.
Many Canadian M152, M37, M43 parts available. 30,000 original mile M152 command truck is having its entire drivetrain swapped out and switching to 12 volt electrics. Turning vehicle into a fully equipped, bug-out, overland expedition truck.
What do you need? Let's talk. All prices are or best offer. Bundle!
CANNOT BELIEVE I STILL HAVE THIS RUNNING ENGINE! I thought everyone desired the larger 251 engine.
Running Canadian 251 engine, includes 24 volt generator/alternater, 24 volt regulator, 24 volt generator to regulator cable, bell housing, clutch and throwout bearing, 4 speed transmission, 24 volt starter, and rare cold start dash pump. Needs fuel pump and carb rebuild. $1,300.00 Recently pulled from truck, ready to be lifted into your trailer or pickup bed. Have video of it running prior to pull.
Front and rear leaf spring lower shock mounts with shocks $50.00 for all four.
Set of 4 guages (no oil pressure) and 2 gauge lights $50.00
Ceiling ventilator ducts (2) $100.00
Many more pieces, parts, misc. 24 volt bulbs
Contact Glenn at 602-956-6695
Phoenix, AZ 85018
Phoenix, AZ 85018
