replacing front axle shaft
Posted: Sun Apr 02, 2017 1:30 am
by isaac_alaska
bought another truck, this has a broken front axle shaft, the short side. I'm pretty sure i have the technical manual with the exploded views and probably the clearance specs for the joints, and i think i have a few replacement joints and axles, even if they aren't new they should work.
is there anything else i should have on hand before i start? bearings, seals, etc? So far i've only driven the truck about 3 blocks, because the carb was leaking fuel and it was running really rich. so much for fresh oil...guess i'll be changing it again. it's already nice and black. at least it should stay clean longer this time, with the carb rebuild i just did :)
Re: replacing front axle shaft
Posted: Sun Apr 02, 2017 4:49 am
by ashyers
Isaac,
Try this:
http://www.m37rebuild.com/Suspension%20 ... Items.aspx
Nice photos and such. It's pretty easy, but pulling the bushings can be a bear. You'll also need 10lbs of grease!
Dave has some neoprene inner axle seals that may be of value at:
http://jobrated.com/index.html
Posted: Sun Apr 02, 2017 10:35 am
by isaac_alaska
thanks for the links! looks like to get the inner seals and bushings out i would have to pull the center diff? does the inner seal slide all the way thru to the outside, or does it get installed thru the center cavity?
*edit*
I found my service book which covers the axles, and it has a very good diagram of how everything goes together. Should answer most of my questions :) (inner seals and bushings come out thru the knuckle, no need to remove the third member)
Posted: Sun Apr 02, 2017 10:26 pm
Pull the center chunk as a last resort but if you get to that point, do so then slide a long piece of pipe across to contact the far bushing, drive it out, then reverse sides and do the same.
Posted: Mon Apr 03, 2017 9:55 am
by 52PLOWERWAGON
Another truck oh boy ...
ANY pics of the beast ?
Posted: Mon Apr 03, 2017 1:35 pm
by isaac_alaska
one more question, I see there's supposed to be a spring inside the felt retainer on the knuckle. one side is completely missing the felt, spring, and metal retainer. i found the felt and retainer on ebay, but i haven't been able to find the spring. how important is it? or does anyone have a link or a source for the spring?
*edit*
nevermind, i should have checked MWM first...not only does john have the spring, the whole kit is much cheaper than any of the individual prices on ebay :)
Posted: Mon Apr 03, 2017 6:51 pm
by 06boblee
Wow! That one has the new gravity fed fuel delivery system already installed.
Posted: Tue Apr 04, 2017 9:32 am
by isaac_alaska
06boblee wrote:Wow! That one has the new gravity fed fuel delivery system already installed.
plus an electric pump behind the cab, plus the mechanical pump is still connected. plus leaky float needle. it gets LOTS of fuel...
carb is rebuilt, need to reinstall it. and i need to track down a front passenger side axle. all 4 pieces of it. i think i have one...it's a matter of finding it.
Posted: Wed Apr 05, 2017 7:26 am
by 52PLOWERWAGON
geese, Isaac you have a problem, you have a very good problem though 8) :lol:
i just talked to the guy i sold my first m37 to and he bought a nice rust free one with no bed and no motor
he said he wants 1500 dollars for the pair of them
so I'm going m37 shopping soon
and a guy that came to look at my truck said he knows where there are a couple more m37s hiding
so i will be stopping to see him soon
i may be developing a problem :D
