Correct Speed Sign on Dash
Posted: Mon Sep 26, 2016 9:14 am
by carolinamv
Whats the correct speed sign for the M37, the one that says On Post Speed Limit etc?
And where exactly did they go , or most of them go? Thank you , Jay
Re: Correct Speed Sign on Dash
Posted: Mon Sep 26, 2016 12:14 pm
by just me
That isn't an ordinance item. It would go, if it was required, where the local command ordained it.
Posted: Mon Sep 26, 2016 1:45 pm
by isaac_alaska
I think there should also be a plaque that lists maximum top speed in each gear, but i don't remember where it is installed, because i think mine is missing
Posted: Mon Sep 26, 2016 2:00 pm
by Elwood
isaac_alaska wrote:I think there should also be a plaque that lists maximum top speed in each gear, but i don't remember where it is installed, because i think mine is missing
That's the "Transmission and Transfer Gearshift Instruction Plate", which is mounted on the dash panel, above the steering column.
Posted: Mon Sep 26, 2016 4:43 pm
by carolinamv
Right,
So when command wanted them where did most of them go and what were the speeds for the M37? Thanks guys
Posted: Tue Sep 27, 2016 9:53 pm
by Tom P
My M37 had a decal center of dash below windshield "Max Speed 45MPH"
Have also seen it in stencil.
Tom
Posted: Wed Sep 28, 2016 4:37 pm
by carolinamv
I thought I saw some that say Max Speed and On Post Speed or something like that. I might be over thinking it.
