Flex brake lines
Posted: Tue Sep 13, 2016 7:51 pm
by Dutch
Can anyone tell me the number of flexible lines needed to do redo the brake system? I see suppliers sell 2 long and 2 short lines, but I read somewhere that you need 3 of one length and 1 of the other. Can anyone give me some insight on what need? Has anyone used the Napa 4000 and 4900? Do they fit? I ordered new cylinders from Napa and I wanted to try the hoses, but I'm not quite sure what I need.Any problems with them not being armored coated or whatever it is called with lack of a better term spring wrapped around it. I just got my first 37 and let's just say I have a lot of learning to do.
Re: Flex brake lines
Posted: Wed Sep 14, 2016 8:13 am
by Kaegi
I don't know on the lengths but you can get the armored ones from midwest mil or VPW. I have noticed the parts store hoses these days are wimpy Chinese garbage.
Posted: Wed Sep 14, 2016 2:50 pm
by just me
2 long and 2 short on mine.
Posted: Wed Sep 14, 2016 9:56 pm
Ditto last post...
Posted: Thu Sep 15, 2016 7:06 am
by 52PLOWERWAGON
Kaegi wrote:I don't know on the lengths but you can get the armored ones from midwest mil or VPW. I have noticed the parts store hoses these days are wimpy Chinese garbage.
my grandpa just put a new brake hose on his ranger
instructions in box said
warm to room temp before installation to avoid cracking or breakage
that will work good on a cold winter day when you hit the brakes
Posted: Fri Sep 16, 2016 5:53 pm
by w30bob
Hi Dutch,
There are 4 flexible brake lines (hoses) and all have the spring or "armor" covering. 3 are the same length and the 4th line is a different length. I don't have an ORD 9 handy, so I can't tell you which line is different, but I think three are shorter and one is longer. Most folks who sell the lines give you two short and two long, as being a little longer doesn't hurt anything. The current reproduction hoses are made in China, but I don't know how good they are.
So.....do the lines need to be spring or armor covered? The spring cover is there to prevent abrasion to the lines from rocks, sticks, etc. if you don't drive off-road you don't need the covering.
Regards,
Bob
Posted: Tue Sep 20, 2016 4:40 pm
by Dutch
Ok thanks for the help guys!!
