Door window seals popping out
Posted: Sun Apr 24, 2016 1:31 pm
I have an annoying issue with the seals that are attached to the cab roof for the doors. You screw on the metal piece and you slip in the rubber seals after. If you do it with no glue they pop out every time the window hits it when you close the door. I've tried weather strip adhesive and that don't hold. Thee manual calls for weather strip cement. What is that?
