front knuckle rebuild question
Posted: Fri Apr 22, 2016 4:44 pm
by Cav Trooper
Do the felt seals get a coat of grease or saturated before install in the knuckle rear seal. Also torque spec on all trunnion bolts and spindle bolts?
Re: front knuckle rebuild question
Posted: Tue May 10, 2016 1:43 am
by HingsingM37
Soak the felts in a light oil. Don't forget to reinstall the springs in the felt retainers. As for the bolts, are you using the original bolts or GR8?
