anybody got a vpw high preformance camshaft
Posted: Sat Dec 05, 2015 2:17 pm
by 52PLOWERWAGON
looking for reviews before I order
I don't know anything about cams some one please educate me so I at least have an idea what I'm talking about.
Re: anybody got a vpw high preformance camshaft
Posted: Sun Dec 06, 2015 4:25 pm
by just me
Cams are magical mystery math. What are you trying to do? Most of the times, for basically stock engines, they are wasted expense. You can move torque curve up or down the rpm scale but with our flat sixes, the curve peaks just off idle and is pretty flat to the top of the rpm range. Without adding bigger or more carbs, bumping compression and balancing for higher rpm operation, the stock ones should be fine.
Posted: Mon Dec 07, 2015 8:27 am
by RMS
I was under the impression that that the vpw cam had more lift (410)designed to work better with today's petrol giving you increases in torque and hp at the same rpm. granted bumming the compression by installing a car head or milling down your stock head is still the best $ to gains.
Posted: Tue Dec 08, 2015 9:44 am
by 52PLOWERWAGON
thanks gonna order overhaul parts today
Posted: Mon Dec 14, 2015 8:45 am
by Kaegi
I have never used the VPW cam as I have a cam grinder here in WA. Delta Camshafts in Tacoma . They will grind it how ever you want. or just tell them what your doing and they will suggest one. big improvement over stock. I also recommend shaving .060 or more off stock head. The stock cam is designed for 70 octane fuel. so 89 octane is like race fuel for stock cam;. there is tons of room for improvement. a new cam and shaved head really makes the truck drive great!
Posted: Tue Jan 05, 2016 6:19 am
by 52PLOWERWAGON
I ordered one :twisted:
Posted: Tue Jan 05, 2016 7:14 am
by CSCameron
Who did you order from and what did you get?
Posted: Wed Jan 06, 2016 12:14 pm
by 52PLOWERWAGON
vpw it is custom ground for more duration
Posted: Fri Jan 15, 2016 2:08 pm
by 52PLOWERWAGON
I cant wait to try it :mrgreen:
it came with a spec sheet should I post pics
Posted: Fri Jan 15, 2016 2:10 pm
by 52PLOWERWAGON
Kaegi wrote:I have never used the VPW cam as I have a cam grinder here in WA. Delta Camshafts in Tacoma . They will grind it how ever you want. or just tell them what your doing and they will suggest one. big improvement over stock. I also recommend shaving .060 or more off stock head. The stock cam is designed for 70 octane fuel. so 89 octane is like race fuel for stock cam;. there is tons of room for improvement. a new cam and shaved head really makes the truck drive great!
mine was ground by ISKY RACING CAMS
Posted: Fri Jan 15, 2016 2:14 pm
by isaac_alaska
52PLOWERWAGON wrote:I cant wait to try it :mrgreen:
yes, we love pics around here.
Posted: Fri Jan 15, 2016 4:02 pm
by 52PLOWERWAGON
it might be a while but they will get up
Posted: Tue Feb 16, 2016 8:48 am
by mg1978
Here are the Isky cam specs for the Dodge 230 flathead engine. This is the cam that Vintage Power Wagons is selling. It is a NOS cam that is reground by Iskenderian Racing Cams for them.
Posted: Sun Apr 17, 2016 3:31 pm
by 52PLOWERWAGON
that cam gives the engine lots more response
and man is it PEPPY! 8) :twisted:
now my truck sounds like a HARLEY !!!!!! :D :D :D
