Transmssion Specifications for the C-88761
Posted: Mon Nov 02, 2015 6:57 am
by LegionPiper
Hi Folks,
I have two spare Transmissions, which I am using to rebuild one good one from.
Both transmissions are missing bolts holding the shift tower in place.
While documentation states part number & tear down instructions, I can't seem to find the actual bolt & thread sizes.
Given part numbers, there appears to be three types of bolts used on the shift-tower cover.
Would anyone happen to have those details so that I can source them from a fastener store ?
Thanks so much,
Derek
Re: Transmssion Specifications for the C-88761
Posted: Wed Nov 04, 2015 9:01 am
by LegionPiper
Hi Folks,
If it's not possible to find the Bolt Specs for this transmission, if anyone has a spare tranny, can they please measure length, diameter, and thread size ??
Thanks so much
Posted: Wed Nov 04, 2015 2:06 pm
by isaac_alaska
One of the manuals has the specs for bolts. I don't have that manual, but I know someone does, because they gave me the specs for a carb bolt I was looking for once.
Posted: Wed Nov 04, 2015 3:04 pm
by Sal
On my 88950 old style transmission I have 3/8x16x 7/8" long hold the shifter tower down.
Hope this is what your looking for Derek
Posted: Wed Nov 04, 2015 3:18 pm
by isaac_alaska
also, if you list the part #'s, probably someone will be able to look those up and tell you just what they are
Posted: Wed Nov 04, 2015 3:35 pm
by w30bob
There are a total of 6 bolts that hold the top cover on the 88761 tran;.
(5) PN 1221126, 3/8-16 NC-3 x 7/8
(1) PN180129, 3/8-16 NC-3 x 1 7/8
Posted: Thu Nov 05, 2015 2:37 pm
by LegionPiper
That's fantastic !
Thanks so much guys.
Say Bob,
any insight as far as why the part illustrations identify the bolts, washers, then Bolts & Washers together ?
L - Screw and Lockwasher CC-272524
M - Screw Short CC-1664345
N - Lockwasher CC-110405
P - Screw Long CC-1664346
Q - Screw and lockwasher Short CC-423353
Hmm, I see that I am dealing with a different manual.
Same sizes as the ones you've highlighted though, which is good !
The illustration was really hard to understand.
That one long bolt, where would it go, I guess I can check out the holes with a feeler gauge.
That would quickly solve any questions about depth.
Posted: Thu Nov 05, 2015 3:36 pm
by w30bob
The long bolt goes in the front left corner of the cover......it's obvious when you take a look at it, as the cover is much thicker there in that corner.
Posted: Thu Nov 05, 2015 4:00 pm
by LegionPiper
Sorry Bob,
One quick clarification.
3/8-16 NC-3 x 1 7/8
This means:
it's a 3/8 diameter bolt.
16 Threads per inch
National Course standard
( Not sure what the -3 stands for ? )
1 7/8 inches in length.
Posted: Thu Nov 05, 2015 5:26 pm
by w30bob
Hi Legion,
The "3" is the class of fit for the threads. They range from 1 to 3 with 3 being the tightest fit. Screws and bolts are way more complicated than they appear.........I doubt the guy down at the hardware store would know the class fit of the hardware they sell. Here's a good site if you want know more........it talks about thread fit about 1/4 way down the page. Enjoy!
https://www.fastenal.com/content/feds/p ... Design.pdf
