Differential Bearings.........EXPENSIVE!
Posted: Sun Jul 12, 2015 4:32 pm
Howdy Boys,
Well, I've got a differential or two that at some point are going to need going thru to be useable and will likely need some bearings replaced. Even if they're marginal I'll replace them, as it doesn't look like a fun job I'd like to repeat in the near term. I've already got the spider gear kits and parts, so I focused on bearings. I started pricing the 5 bearings needed and WOW are they expensive! I didn't dig too hard on the web, but used Amazon's prices for the Timken bearings. The total for the 5 come out to right around $700.
I assume Timken are the best, but I'm sure there are other bearings out there that aren't too shabby in comparison. Has anyone cross referenced the Timkens to another decent quality bearing manufacturer? Who in the bearing world is comparable to Timken these days?
thanks,
thanks,
