Newstar Flasher unit issues...anyone else???
Posted: Sun May 17, 2015 1:03 pm
I picked up a new flasher unit at the Aberdeen show...unfortunately I can't remember who I bought it from. Put it on my M37 and when i moved the signal arm the circuit breaker immediately tripped it did this three times. (Put it on the M35A2 and it fried the jumper wire I used to ground it...Obviously unit is faulty.
The only reason I needed a new unit was I had taken the one off my M37 to put on a friends M35A2 whose unit had failed.
I am assuming it is a Newstar unit as it has NSN and part number but unlike all the original ones it doesn't show a manufacturer. (My old one was Swiss controls)
Looking around most of the ones you see new are also probably from Newstar so I wonder if this was a one off failure or is there an issue with many of their flasher units. I noted that the terminals were not marked in the rubber inset as the original units were.
