Page 2 of 12
Re: SC M37
Posted: Wed Jan 11, 2017 4:33 pm
by sturmtyger380
Its been awhile since I posted work on my M37.
How much force do you think is needed to bend the casting of the rear lift bracket?
Re: SC M37
Posted: Wed Jan 11, 2017 4:35 pm
by sturmtyger380
Getting ready to pick the transfer case.
Re: SC M37
Posted: Wed Jan 11, 2017 4:37 pm
by sturmtyger380
Stripping the body down.
Re: SC M37
Posted: Wed Jan 11, 2017 6:11 pm
by m-37Bruce
I don't think the castings will bend, even with heat?
Re: SC M37
Posted: Wed Jan 11, 2017 6:34 pm
by Elwood
sturmtyger380 wrote:Its been awhile since I posted work on my M37.
I would have expected the stamped frame to yield before the casting.
Re: SC M37
Posted: Wed Feb 08, 2017 4:46 pm
by sturmtyger380
I decided to start working on taking out the rear sill. Like all you guys out there the bolts on the rear of the sill turned and then the weld nuts broke loose. So out with the grinder.
The bed is really not in that bad a shape but this one spot is really bad like Swiss cheese. They must have had something here that corroded the metal.
Grinder and punch is the way to go!
Re: SC M37
Posted: Thu Feb 09, 2017 4:56 pm
by sturmtyger380
Okay, I cheated. :P
Other than the weld nuts breaking loose the angle metal does not look so bad.
This whole area of the sill is rusted but only in this one spot. Strange. Here is the bottom:
Alan
Re: SC M37
Posted: Thu Feb 09, 2017 6:00 pm
by m-37Bruce
What do the bed bolts look like?
Re: SC M37
Posted: Fri Feb 10, 2017 4:07 am
by sturmtyger380
Do you mean the big stair bolts on the sill? The big bolt in the area of the rust was really eroded and had to be cut off. The one on the passenger side was not too bad and I was able to remove the nut and pull the bolt out no problem. The rest of the bed to frame bolts came out fine. The phillips head bolts I could not get to turn and just ground them off and punched them out.
The rear sill bolts that survived look like the threads got abused when I was turning them out.
Re: SC M37
Posted: Fri Feb 10, 2017 1:22 pm
by m-37Bruce
John at Midwest has the replacements, I don't remember $$'s? Mine came apart a little easier, the captive nuts that spun were easy to reach with vice grips.
Re: SC M37
Posted: Fri Feb 10, 2017 4:44 pm
by sturmtyger380
Here are the bed bolts. Not in a shape that I would want to reuse.
The passenger side metal angle, I got all but one bolt to come out. The one left I got out. This angle bracket had all the weld nuts intact.
The drivers side bracket where there is more rust, only one of the weld nuts was left. I have a new hex nut sitting in place and will weld that and others to fix it.
Here they are ready to prime. I did some welding on the original weld nuts to help reinforce them.
Re: SC M37
Posted: Fri Feb 10, 2017 6:31 pm
by m-37Bruce
I think your right about the bed bolts, the welding on the brackets looks great.
Re: SC M37
Posted: Mon Mar 06, 2017 2:46 am
by sturmtyger380
Somehow I keep getting pulled off of the M37 to work on other projects. I still try to do a little each day.
I got the drivers side rear panel just below the tailgate straight but the edge of the piece was really chewed up. I could have used a bunch of bondo to create an edge but don't like doing that. So I cut out a section of an old truck and will weld it in place on the better truck.
Ready to weld in the patch panel:
Re: SC M37
Posted: Mon Mar 06, 2017 1:05 pm
by 52PLOWERWAGON
those are cool clamps where'd ya get them from
Re: SC M37
Posted: Tue Mar 07, 2017 3:59 am
by Elwood
52PLOWERWAGON wrote:those are cool clamps where'd ya get them from
http://www.eastwood.com/intergrip-panel ... -of-4.html
