bed side straps
Posted: Sun Dec 21, 2014 8:43 pm
by Cav Trooper
I saw a M37 with straps attached through the loops on the sides of the bed just under the side rails. What are the straps for? Who has the straps?
Re: bed side straps
Posted: Sun Dec 21, 2014 10:28 pm
The straps hold down the bed bows when the bed top is removed. The Ahl Resto Guide has a nice photo showing the setup. I'm not aware of anyone who makes replacements.
Re: bed side straps
Posted: Mon Dec 22, 2014 6:17 am
by 52 M-42
You can get replacement straps from the usual suspects (New Life Canvas, WeeBee, Midwest Military, etc).
HOWEVER, if you strap those bows behind the cab with the side straps, they will rattle, bang and clang, making your driving experience a misery (all the noise is right behind your head). A better use for those straps is to hold the forward end of the cargo bed passenger seats tight against the sides (so they don't rattle).
So, where to store the bows then? I made some vertical bow holders for the front of the cargo bed that just bolt on. The front bow stays in place and the other two bows are directly behind it. I use a strap (about 10" long I think) to hold all 3 together at the top so they don't rattle. I find it works much better for me. They are easier to get to and deploy, also. I can post pictures if anyone is interested.
As you might have guessed, I really don't like secured or unsecured stuff rattling around.
52 M-42
Re: bed side straps
Posted: Mon Dec 22, 2014 7:17 am
by Cav Trooper
thanks for the info. Will probably never use the straps but, might add them for look.
CT
Re: bed side straps
Posted: Wed Dec 31, 2014 4:54 am
by sturmtyger380
52 M-42 wrote:I made some vertical bow holders for the front of the cargo bed that just bolt on. 52 M-42
Got any photos of this setup you made? I don't like rattles either. They keep you from hearing things that might be going wrong.
Alan
Re: bed side straps
Posted: Wed Dec 31, 2014 6:27 am
by 52 M-42
PM me your email and I'll send you some pictures when I get home tonight (or tomorrow morning).
They are easy to make. Just a little welding and grinding (to make them pretty). They just bolt on to existing fasteners, so they are not permanent alterations (for the purists).
Re: bed side straps
Posted: Sun Jan 04, 2015 10:29 am
by 52 M-42
Re: bed side straps
Posted: Fri Jan 16, 2015 4:49 am
by T. Highway
Storm,
Great looking brackets that you added to hold the bows.
Re: bed side straps
Posted: Fri Jan 16, 2015 6:15 am
by 52 M-42
Thanks, Bert!
