Cylinder head install and Copper spray gasket
Posted: Wed Nov 13, 2013 7:10 pm
I thought I might have had a blown headgasket last winter so I removed the head from the motor, had it milled .020, and am ready to re-install it now (having a newborn really slows down these projects!). The head gasket looked fine. I have a new Best Gasket which is copper on both sides and Napa Copper Spray-A-Gasket. I plan to run a tap in all the headbolt holes to clean them up. I do have a few questions though, as I have never put on an automotive head, only dirt bike heads and lawnmowers.
1) Can I use the Napa Copper Spray-A-gasket for the headbolts or should I get a silicone based thread sealant for the bolts? The napa spray gasket does say it is listed for bolt threads
2) Do I just spray a couple of coats on each side of the head gasket and assemble the gasket and then the head?
3) I was planning on re-using the headbolts I have since they appear to be in pretty good condition. I was told they are not the type that stretch and are one use only. Is this good info? I will find all the torquing specs and sequence in my manuals, but would different sealants require different torque values?
I never did find the cause of the emulsification under the oil cap, and I am hoping it is condensation from the short trips I use the truck for. I am probably dreaming, but at this time I cannot deal with a motor rebuild. Any info or views wold be appreciated. Just don't tell me to strip the motor down and magnaflux it, as that is not happening. Thanks
