Rear Differential / Ring & Pinion Options
Posted: Mon Nov 11, 2013 6:06 pm
by dispatcher1011
Hello all,
I think I may need a ring and pinion for in my 1954 M37.
Where can I find the best deal on a ring & pinion?
Keeping it stock.
Might add spider gears while it is that far apart, too... so any help there too would be great.
Seems that some moisture got in the axle.
I might post up some pics later, too, of it.
Thanks in advance.
Re: Rear Differential / Ring & Pinion Options
Posted: Tue Nov 12, 2013 4:45 am
Might be easiest to get a used center chunk from someone here on the forum-several guys have parts trucks....
Posted: Tue Nov 12, 2013 6:30 pm
by Brigand
dispatcher1011 wrote:Hello all,
Keeping it stock.
Thanks in advance.
What part of the country are you in. I've got a couple spare pumpkins in So Cal.
Posted: Wed Nov 13, 2013 6:48 pm
by dispatcher1011
Pennsylvania... Shipping might be kinda high?
Posted: Thu Nov 14, 2013 1:24 pm
by Brigand
dispatcher1011 wrote:Pennsylvania... Shipping might be kinda high?
True, Shipping would probably make them unatractive. The good news is that the 1 ton PW's from WDX through WM300 use the same diff. You should be able to scout one up close to home.
