Wiring an Electric Feul Pump
Posted: Sun Nov 03, 2013 7:40 am
by Chris P
When wiring an electric feul pump where have people tied in the positive wire?
Re: Wiring an Electric Feul Pump
Posted: Sun Nov 03, 2013 10:43 am
by tbone1004
ignition switch is a good place to tap into since it should handle high loads with no problems. Otherwise you can run a relay from anywhere and put an extra switch on the dash
Posted: Sun Nov 03, 2013 11:20 am
by jimmy_stikx
Mine is wired into the ignition somehow.
Posted: Sun Nov 03, 2013 5:03 pm
by MarkPick
Wired mine to the ignition switch.
Posted: Mon Nov 04, 2013 4:02 am
Same same.
Posted: Mon Nov 04, 2013 7:29 am
by Chris P
Thanks.
Here's an old topic on the ignition switch, for any that might be looking for it.
http://www.g741.org/PHPBB/viewtopic.php?f=3&t=3695
