Relays
Posted: Sun Mar 23, 2008 4:08 pm
I have an unusual 12/24V set up in my truck with
High Power Zeners to produce the 12V while keeping the
24 V for Charging and starting.
Anyway I use 24V relays a lot and I just found these.
http://www.1sae.com/products/bldgcontrol/pam/index.asp
They are dual voltage 120VAC and 24V and have a form "C"
set of contacts rated at 10 Amps (form "C" is a N.C and an N.O.
with a common lead between them).
They are reliable, have an LED indicator, and are relitavely cheap
($8 at ADI).
Anyone thinking about 24V relays should check them out.
J.B.
($8 at ADI).
J.B.
