Ok I need some parts
Posted: Sat Mar 22, 2008 12:26 pm
Ok I need some parts but money is tight right now but if it is a good price I will look in to it. These are the parts I need: the whole carb setup including the air cleaner, the top draglink, all glass, wiring harness front and back, gas tank, the U joint looking thing for the steering rod that holds it to the dash (lol), distributor, and 24v generator. Like I said money is tight and some of the more expensive things I will not be able to get till May. But I figured id let you know what I need.
Thanks.
Thanks.
