1953 M-37 Original, running, hardtop
Posted: Mon Jul 01, 2013 7:47 am
I have a very original 1953 M-37 for sale. I am located in Monroe, WA just 40 minutes NE of Seattle. Truck has clear Washington title and sales plaque on dash from Wittenburg Motors of Midway, WA. All tags and plates are in tact. Engine is original 230 and has 125 compression on all cylinders. Carb was rebuilt with NOS kit a couple of months ago. Master cylinder was rebuilt with NOS kit at same time. Charging system works excellent and has new solid state voltage regulator and spare non-solid state unit. Original wheels with 9,00-16 non-directional military tires in good shape, but not new. Metal hardtop. All gages work except speedo has no cable and shows 12k miles. Spare drive belt, bendix, vent control, manuals. Also new batteries a couple of months ago. This truck is parked inside and has been stored inside last 9 years. Body is very solid and door bottoms perfect. Only rust is in front bed corners where some dirt was left over time. Flat area of bed makes it a easier fix to make truck perfect. Needs paint. Otherwise it has been well maintained and all the fluids were checked and up to level. There aren't any leaks although there is some buildup from seepage over the years. This truck runs out well, starts instantly and runs smoothly. A good sanding and a couple of gallons of paint and you are in business.
Selling for $4,500
Call Bill at: 425 260-1395
Selling for $4,500
