distributor gasket
Posted: Tue Jun 04, 2013 7:33 am
by jimmy_stikx
Does anyone know the part# for the gasket between the block and the dizzy?
Re: distributor gasket
Posted: Tue Jun 04, 2013 8:19 am
by T. Highway
jimmy_stikx,
# 1352 Distributor Base gasket from Best Gasket.
Posted: Tue Jun 04, 2013 8:47 am
by jimmy_stikx
Bert,
I just checked their site and there's no listing for it. A part # search is just as fruitless.
Will a Fel-pro 6464 work?
Do you know its composition? I might be able to just make one.
Posted: Tue Jun 04, 2013 12:17 pm
by T. Highway
http://www.bestgasket.com/pop_up_pictur ... ber=RS510C
The gasket is a fiber material that I would guess is about .040" - .050" thick.
I'm not familiar with the Fel-Pro gasket.
Posted: Tue Jun 04, 2013 1:32 pm
by jimmy_stikx
So I'll check the Felpro one,
I would like to not have to buy an entire gasket set for one gasket.
-Jim
Posted: Tue Jun 04, 2013 4:50 pm
by T. Highway
My local vendor will sell one or two at a time, no need to buy the whole set. They are great people to work with.
I would cut my own if I only needed one pc.
Posted: Tue Jun 04, 2013 5:24 pm
by jimmy_stikx
Bert,
Do you know the inner and outer diameters, in case I need to cut one?
Thanks in advance if you do.
-Jim
Posted: Tue Jun 04, 2013 7:54 pm
by jimmy_stikx
So I ended up with a felpro mounting gasket for chevy small blocks Part number at autozone is 70194.
Seems to be working so far.
I found it by pressing a piece of card stock over the mounting surface and matching up a gasket to the oil profile on the card.
