Felt flange oil seal installation
Posted: Mon Oct 22, 2012 4:26 pm
Reference:POWER TRAIN BODY AND FRAME TM 9-8031-2 Paragraph 79
So before I saturate the seals with oil I decided to try a dry fit. Jammed in as tight as they will go they stick out the end of the retainer about am inch. I can't imagine that soaking them in oil will make them shorter. The new felts are from John at Midwest so I assume they are the correct length. Has anyone had the same experience? Do you just slice off the extra? Manual doesn't say anything about that. I know the flat oil seal joint covers the gap at the top. Any observations would be appreciated. Thanks.
