turn signal
Posted: Fri Oct 19, 2012 6:24 pm
by jim0311
I have a signal stat 730 can I use this with the new electronic flasher? Any help is appreciated.
Jim
Re: turn signal
Posted: Sun Oct 21, 2012 9:32 am
I believe the unit you have is quite old, but will admit that a 730 is not one I've heard of before. The typical units that work great with solid-state flashers is the signal-stat 900 series. The 900 wires exactly like the mil spec control switch, and will work great with either the mil spec flasher or a conventional unit. The cost for a 900 series at NAPA and other outlets is around the $70 range, but is a switch you can mount and forget; very reliable.
Re: turn signal
Posted: Sun Oct 21, 2012 11:36 am
by jim0311
Thank you. I got it working but the 900 sounds better.
Jim
