Anybody Know What's Inside a PCV Valve?
Posted: Thu Oct 18, 2012 3:47 pm
by w30bob
Hi Guys,
The reason I'm asking is I got a nice dirty rusty M37 PCV in a box of nuts and bolts from the swap meet and I was going to dunk it in hydrochloric acid (Muriatic Acid) for a quick bath. But I wasn't sure if the internals were just a metal ball and metal spring, or something the acid would destroy. Anybody ever taken one apart to see what goodies are inside?
thanks,
Re: Anybody Know What's Inside a PCV Valve?
Posted: Thu Oct 18, 2012 9:45 pm
Primarily a spring and a ball, but not all PCV valves are alike-the ball weight and spring tension varies depending on the engine. Using an incorrect one can really screw things up.
Posted: Fri Oct 19, 2012 2:54 am
by powerwagontim
The Donaldson valves do get gunked up, and are made to be dissassembled, cleaned and put back. If you shake it you should hear some movement inside.
Tim
Posted: Fri Oct 19, 2012 4:44 am
by T. Highway
I was wondering about the valve internals myself just last night.
I took mine apart cleaned the internal single part (a metal poppet) no sign of a spring. I media blasted the external portion of the valve and re-blued it. I then assembled it the same way I took it apart and started to wonder if there should be a spring inside.
I will post a picture of refinished valve tonight. It looks nice but I don't know if it will function correctly. I was going to call Charles later today and ask him about it.
Posted: Fri Oct 19, 2012 5:10 am
by w30bob
Hi Bert,
Can you tell me how you "re-blued" it?
thanks,
Posted: Fri Oct 19, 2012 9:59 am
by T. Highway
Hi Bob,
I'll get the name of it tonight and post it along with the picture.
Posted: Fri Oct 19, 2012 1:47 pm
by jordankjcm
Bert,
TM9-8030 has a nice diagram of the internals of that valve on page 165. No spring, just that round tapered metal piece (weight) looks to be inside.
Jeff
Posted: Fri Oct 19, 2012 1:54 pm
by jordankjcm
Bert,
You have a PM.
JJ
Posted: Fri Oct 19, 2012 3:26 pm
by w30bob
Hi Guys,
Jeff....you're right. I pulled one of my PCV valves apart (the Donaldson) and it had the pintle you describe without any spring or check ball. I also took apart two other PCVs that I believe go to the M38 Jeep. That one has a spring and a cone with an orifice at the top of the cone. Both were dirty and needed a good cleaning. I didn't have my camera with me or I would have posted some pics.
Posted: Fri Oct 19, 2012 6:24 pm
by T. Highway
I talked with Charles today and he confirmed what you guys are saying, no spring inside the valve.
Here is a picture of my refinished valve. I used Vans Gun Blue, this is a cold gun blue that if you use it on slightly warmed steel it will look and work as well as salt blue.
