seat belt mounting question
Posted: Thu Sep 06, 2012 4:32 am
by Cav Trooper
Does anyone have any pictures and suggestions on mount seat belts in an M37. I think the mounting bolts will need some reinforcement but I don't know how much or if there is one better area to bolt them to over just a random spot.
CT
Re: seat belt mounting question
Posted: Thu Sep 06, 2012 8:08 am
by w30bob
CT,
I can send you some pics later of how the seat belts were mounted in my M....but I'm at work now and don't have acccess to the pics.
Posted: Thu Sep 06, 2012 10:04 am
by Cav Trooper
Thanks, much appreciated.
CT
Posted: Thu Sep 06, 2012 2:24 pm
by W_A_Watson_II
I have a modified seat base. but you can see my
lower 4pt harness attachment locations here:
Posted: Fri Sep 07, 2012 3:36 pm
by m37jarhead
If you use seat belts with a shoulder strap or use a four point harness, be sure to mount
the upper part of the shoulder strap at least 4" inches above your shoulder height.
Anything lower than your shoulder height will drive your body down and forward
in a crash.
You might also "google" info on mounting seat belts and get more info from the experts.
JB
Posted: Tue Sep 11, 2012 8:34 pm
by w30bob
CT,
So sorry......I totally forgot about your post. Out of sight....out of mind I guess. Here's the pics of how my seat belts were mounted. The first pic shows the driver side belts mouted to reinforced holes in the floor under the bottom seat cushion with bolts. The passenger seat belts were attached to the two bolts in the back wall of the cab where the bottom of the upper cushion attaches to (second pic). I hope this helps.
