Spark Plug wires
Posted: Thu Feb 02, 2012 8:10 am
by rtquig
Do you have to purchase an entire set of 6 spark plug wires? I only need 2, seems water got under the hood and rusted the metal housing on the spark plugs and I can't get the threads out from the plug cables. The Plug wires are braided and in excellent condition. I have been putting penetrating oil on them every night in the hopes of somehow getting them apart. The other 4 wires unscrew easily by hand. I have seen sets online that cost around $200, but if I could get away without buying the whole set it would help.
Re: Spark Plug wires
Posted: Thu Feb 02, 2012 8:18 am
by snowdad
You should get by with 2 IF the other 4 wires are in good shape on the inside. From time to time eBay has them at a very reasonable rate. You can use the ones off of an M-38/M-38A1 also if the length are the same.
Phillip
Posted: Thu Feb 02, 2012 9:37 am
by rtquig
The wires are all in good shape, the problem is part of the spark plug that tightens into the cable rusted out and broke off flush with the plug wire connection. I am going to see if I can get the rusted plug out of the connection but If I can get new wires it would save me some tedious work.
Posted: Thu Feb 02, 2012 11:11 am
by powerwagontim
I have some used ones here, PM me if you are interested in some.
Tim
Posted: Thu Feb 02, 2012 1:17 pm
by rtquig
Okay, I will give it one last try tonight, and if I can't get it right I will PM you. Thanks,
Rich
Posted: Thu Feb 02, 2012 5:07 pm
by rtquig
Tim,
I sent a PM, I could use 2 cables.
Rich
