Page 1 of 2
Bumperettes mounted-PTO next...
Posted: Wed Nov 09, 2011 1:09 pm
Installed both today-stubborn old bent bumper brackets needed some coaxing but a big C clamp and a BFH took care of 'em. I need to straighten out the right side loop but am pleased with the results!
Re: Bumperettes mounted-PTO next...
Posted: Wed Nov 09, 2011 1:12 pm
And more:
Posted: Thu Nov 10, 2011 4:41 am
by T. Highway
Looks good Gary.
I noticed that your front marker/turn signal lens are amber, did you tint these or are they amber glass?
Posted: Thu Nov 10, 2011 5:16 am
Thanks Bert,
Amber glass-got 'em from Memphis Equipment via eBay for $25 for the pair (entire assembly)-a pittance of what they go for now.
Posted: Fri Nov 11, 2011 4:52 am
by T. Highway
Cal_Gary wrote:Thanks Bert,
Are these for a later model M37 or another Mil truck? I need to start watching for some of these.
Posted: Fri Nov 11, 2011 5:11 am
Not OEM for the M37 that I'm aware of-I like the look in the dark-will post a picture this weekend.
Posted: Fri Nov 11, 2011 6:27 am
by monkeymissile
silly question, but.....
Can the stock front leaf springs be used when adding a winch or do you need to use ones with an extra leaf?
Thanks!
Posted: Sat Nov 12, 2011 3:18 pm
Not a silly question-same spring. None of my source manuals list any separate springs for a winch model.
Posted: Sat Nov 12, 2011 3:38 pm
Bert, here's that picture- a little blurry but no mistaking how visible they are.
Posted: Sat Nov 12, 2011 4:10 pm
by monkeymissile
Cal_Gary wrote:Not a silly question-same spring. None of my source manuals list any separate springs for a winch model.
Thanks Gary,
I thought I read or heard that somewhere, would save me lots of work if it's true!
Appreciate the reply....
Justin
Posted: Sun Nov 13, 2011 3:24 am
by M37UK
Another option is to leave the clear glass and go with amber bulbs, as I have. Since this pic was taken I have swapped the bulbs around so that the amber bulb is behind the magnification part of the lens. Works really good for me.
Cheers
Posted: Mon Nov 14, 2011 4:42 am
by T. Highway
Cheers
Stu,
What is the part number for the LED that you used? This was actually what I was ging to do but haven't found the correct buld yet.
Posted: Mon Nov 14, 2011 4:46 am
by T. Highway
Cal_Gary wrote:Bert, here's that picture- a little blurry but no mistaking how visible they are.
Even though its blurry you can see how they stand out at night.
Thanks Gary,
Posted: Mon Nov 14, 2011 5:21 am
I had to run 'em hot on that trip (moving from CA to UTAH) because the trailer lights died as soon as it got dark and I didn't have my multimeter with me.
Posted: Mon Nov 14, 2011 11:35 am
by M37UK
Stu,
Bert, my LED amber bulb doesnt have any part numbers or manufacturers details on it. Presumably a Chinese import.
I have searched through my email but cant find any reference to the purchase of them.
I'm sure I bought them here:
http://www.autobulbsdirect.co.uk/24V-LE ... tor-bulbs/
Will definately be a similar type available in the US I'm sure.
Cheers
