Front frame measurements
Posted: Mon Nov 07, 2011 3:25 pm
by Gerry
Went to add a winch to my non winch truck and it doesn't fit. Looks like I need to spread frame a 1/2 inch Can someone give me the measurements between the frame rails at the winch mounting bolts?
Re: Front frame measurements
Posted: Mon Nov 07, 2011 3:37 pm
Gerry wrote:Went to add a winch to my non winch truck and it doesn't fit. Looks like I need to spread frame a 1/2 inch Can someone give me the measurements between the frame rails at the winch mounting bolts?
Do you have the frame extensions in place?
Posted: Tue Nov 08, 2011 8:13 am
by Gerry
Charles,
Extensions are in place. Thinking maybe the front of the frame may have been jarred closer together sometime in her life
Posted: Tue Nov 08, 2011 9:21 am
What you have is not uncommon. Most of the time you can coax it by loosening the bolts in the extensions, the placing a small hydraulic jack between the rails pushing outward and lowering the winch into place. Not usually a big deal.
Posted: Tue Nov 08, 2011 9:26 am
by Gerry
Charles,
Thanks for the idea. I was going to wait till I could drive it and use hydraulic spreaders at work but now I can do it right away.
Posted: Tue Nov 08, 2011 11:24 am
by k8icu
I think it's like when you put a wheel barrow together you leave everything loose till it's all together and then tighten it up. I was thinking the same think put a bottle jack between the fram and jack it untill the winch falls into place. Good luck with your addition.
Oh and yeah this goes without saying..... PICTURES!!!!
Posted: Wed Nov 09, 2011 1:34 pm
Just did this today as I needed to swap out my PTO shaft before installing my bumperettes-the frame rails all seem a bit offset to the inside and need to be flexed out. Some bottle jacks don't work sideways-I used a scissor jack to do mine.
Posted: Thu Nov 10, 2011 9:03 pm
by Gerry
Gary,
Thanks for the info. Hopefully I can find some time soon. Will the frame spread and stay or do you need to bolt in place and then remove jack?
Posted: Fri Nov 11, 2011 1:00 am
You'll need to keep the jack in place or it will flex back in. Once aligned, hand-start all the bolts, cinch 'em down, remove the jack then finish cranking the bolts down.
Posted: Fri Nov 11, 2011 7:45 am
by Gerry
