Page 1 of 2
FUEL DELIVERY
Posted: Wed Aug 10, 2011 3:22 am
by 8543bob
GOOD MORNING ALL,
Let me lay out what happened; then I am looking for possible reasons. I left my house, the otheray to pick-up my
Water Buffalo, at the boat yard, about a 5 mile drive. After I got off the hwy, doing about 40MPH I stopped at a traffic light, the engine died. It would not re-start, pedal to the floor, let it sit for 15 min, no good. My son towed me to the yard where I left the M overnight. Went back yesterday AM and she fire right up, with lots of white smoke, running real rough. I pulled the plug on the carb bowl and energized the elect fuel pump, let it drain for about 10 sec. Installed the plug and she fired up again and ran smooth. Hooked up the Water Buffalo and towed it about 10 miles, to get diesel fuel. no problem. The air temp was 90 and humid. Vapor lock?? stuck float neddle?? I left the Water Buffalo, full of diesl at the boat yard and used the M most of yesterday, no problem. Yesterdays air temp was 83.. I have two in-line fuel filters after the pump. the pump is located in the engine compartment. YOUR THOUGHTS. Dont need it happening again.
THANKS
BOB
Re: FUEL DELIVERY
Posted: Wed Aug 10, 2011 11:19 am
Issue could be several things, however 1 for sure is the location of your electric pump. It should be mounted as near the tank as possible. Unless you have a pump of special design; it is designed to push fuel, not pull it, and getting it away from engine heat will be a plus also.
Re: FUEL DELIVERY
Posted: Thu Aug 11, 2011 12:50 am
by M37UK
I agree with Charles.
I had similar problems where my truck would run fine, but when switched off, would not start again. I had an electric fuel pump mounted on the inner fender beside the
engine which I think was getting vapour locked and was trying to pull instead of push so I bought a new Facet pump and mounted it in the correct position right next to the bottom of my fuel tank.
I also adjusted the float in the carb as it was too low and was flooding.
I havent had any problems since.
Cheers
Re: FUEL DELIVERY
Posted: Thu Aug 11, 2011 3:29 am
by 8543bob
Thank you much for the replys, I will re-mount the pump and hopefully not run into the problem again.
THANKS
BOB
Re: FUEL DELIVERY
Posted: Thu Aug 11, 2011 4:52 am
by Sal
Bob . When you relocate the fuel pump, You should think about installing one of the filters between the gas tank and pump. This way you can keep the gas going to your pump clean. Also by using a clear filter you can see what's going on in your tank, Rust, sentiment.
Sal
Re: FUEL DELIVERY
Posted: Thu Aug 11, 2011 4:58 am
by M37UK
Sal wrote:Bob . When you relocate the fuel pump, You should think about installing one of the filters between the gas tank and pump. This way you can keep the gas going to your pump clean. Also by using a clear filter you can see what's going on in your tank, Rust, sentiment.
Sal
My Facet pump includes a built-in filter but I think your idea of a clear filter between the tank and pump is a good one!
Re: FUEL DELIVERY
Posted: Sat Aug 13, 2011 3:18 am
by 8543bob
HI SAL AND ALL,
I have a see-thru filter, and another in-line filter between the pump and the carb. The see-thru is clean. After I got the truck running I drained a bit of gas from the tank, to ck for junk and water; it ran clean. The elect fuel pump is a Bendix. it has an internal filter that can be cleaned by unscrewing the twist lock top. I have bought marine gen sets that have these same pumps; they are engine mounted and draw fuel from either the main tanks or a day tank. But , like i said in the original post, "I dont want this happening again".So I will remount the pump near the tank, hopefully this will avoid vapor lock, which is what I think caused my M to stall at the traffic signal. We will see.
AGAIN THANKS
BOB
Re: FUEL DELIVERY
Posted: Sat Aug 13, 2011 3:40 am
by Sal
Bob. Did you check your distributor ? I recently had trouble with mine, She started stalling on me and then it wouldn't start. I found the plate that the points are mounted on came loose. Just a quick thought.....
Sal
Re: FUEL DELIVERY
Posted: Sun Aug 14, 2011 3:26 am
by 8543bob
HI SAL, Good thought, I will ck that too once the rain stops. i had the dist out of the engine last year, when I did the re-build. Everything was fine then, but two summers of fun and NY roads could losen anything up.
THANKS
BOB
Re: FUEL DELIVERY
Posted: Wed Aug 17, 2011 11:27 pm
by hbb
8543bob wrote:HI SAL, Good thought, I will ck that too once the rain stops. i had the dist out of the engine last year, when I did the re-build. Everything was fine then, but two summers of fun and NY roads could losen anything up.
THANKS
BOB
Rain!!! what is that? I heard about it never happens here.
hb
Re: FUEL DELIVERY
Posted: Thu Aug 18, 2011 4:16 am
by Sal
There came a time in this past week that I thought that I would have to put pontoons on the truck...lol
Sal
Re: FUEL DELIVERY
Posted: Thu Aug 18, 2011 9:59 am
by hbb
I will keep dreaming maybe someday it will rain here!
hb
Re: FUEL DELIVERY
Posted: Thu Aug 18, 2011 11:43 am
by M37UK
hb wrote:I will keep dreaming matbe someday it will rain here!
hb
How would you like an exchange visit to Scotland? Then you'll see what rain, wind and cold is like
Re: FUEL DELIVERY
Posted: Thu Aug 18, 2011 11:04 pm
by hbb
M37UK wrote:hb wrote:I will keep dreaming maybe someday it will rain here!
hb
I would love to go there someday! in the 1840's my ancestors immigrated from there. last name Baxter.
hb
Re: FUEL DELIVERY
Posted: Fri Aug 19, 2011 3:27 am
by 8543bob
10" of rain in one day, Has never happened before in the area around JFK Airport, not even the huricanes that have hit us carried that much rain. If it had happened in the winter and it had been snow it would have been 100 inches. Thanks God.
