Body line reveals and tolerances?
Posted: Sat Jun 11, 2011 11:12 am
Hi Guys,
Starting to hang the front sheetmetal. I attached the cheek pieces to the sides of the radiator core support, The front radiator cover the grille and the side panels, no fenders or inner fenders. All attached just finger tight. I then installed the hood, and adjusted it to the cowl, working towards the 1/4" revel mentioned in the TM. I know the front and back adjustment is through the radiator support rods, and the elongated holes in the cheek pieces. The passenger side all line up pretty well, falling nicely below the edge of the hood. The drivers side however is a different story. The cheek piece starts out fine at the edge of the hood in the front, and dives in under the edge 1/2". The side panel then goes from being in 1/2" at the front to flush at the rear. I loosened the 3 bolts that attach the cheek to the core support and installed a 1/2" shim behind it and tightened it back up. This brought the rear of the cheek out where it should be, but I am not convinced this was the right way to accomplish it. What is the distance from the bottom of the hood to the top of the side panel supposed to be?
I can see that someone has already elongated the holes in the drivers side panel to get it up higher in the rear than it ordinarilly would have been, but not enough to get a nice looking reveal.
I realize these trucks were not Rolls Royces, but where do we draw the line?
Tim
Tim
