Bed Bolts...
Posted: Sat May 14, 2011 1:36 pm
by Oddjob
Bed Bolts... I found Six is that it... ? Anything else in the way before I try to remove the bed I should look out for...?
Re: Bed Bolts...
Posted: Sat May 14, 2011 7:11 pm
by 98taco3
i just pulled mine and didnt encounter anything else
Re: Bed Bolts...
Posted: Sun May 15, 2011 9:31 am
by m-37Bruce
6 is it, do you need any replacements? John at;
http://www.midwestmil.com has them.
Re: Bed Bolts...
Posted: Sun May 15, 2011 4:51 pm
by Oddjob
So far all of them came loose no broken or lost bolts but will keep Midwest in mind for anything... The only thing I missed was the detachment of the fuel filler from the tank...
Rubber connection pulled free I thought the neck would slip though the cut out in the bed body... Little did I know...
I'm bad about posting pic's so I better post one...
Put the bed on a trailer so I can start doing the disassembly work when I get stuck on something while doing the brakes... No sense in letting a weekend go to waste...
