Winch and wiper questions
Posted: Thu Feb 17, 2011 10:31 am
by Cav Trooper
I just found a winch LU4 which does not have any of the mounting hardware. I already have a pto but the lower lever pivot mounting bracket or what ever it's called is missing. I have a lead on a set of front bumpers but don't know how much might be missing from them. I may need winch mounting brackets, frame extinsions, definitely need the pto levers, floor lock bracket, pivot mount bracket and eventually cable, chain etc. Anyone have a source other than brand new for these parts? I would like the winch to work but, in reality if it doesn't for now, it will be for show until I can gather enough coin to do it right. Another question, where can I get the correct wiper vacuum switch? I see one on ebay but I can't believe it costs $18 to ship. Last question, are vacuum wipers supposed to park and stay up? My wipers drift down to the vertical position as I am driving.
Re: Winch and wiper questions
Posted: Thu Feb 17, 2011 10:37 am
by creinemann
The wipers are supposed to return to top after the vacuum switch is turned off, for them to drop slowly might indicate a leak. NAPA had a small metal vacuum valve similar that might work.
Posted: Thu Feb 17, 2011 1:09 pm
by anthony manzella
Cav Trooper wrote:I just found a winch LU4 which does not have any of the mounting hardware. I already have a pto but the lower lever pivot mounting bracket or what ever it's called is missing. I have a lead on a set of front bumpers but don't know how much might be missing from them. I may need winch mounting brackets, frame extinsions, definitely need the pto levers, floor lock bracket, pivot mount bracket and eventually cable, chain etc. Anyone have a source other than brand new for these parts? I would like the winch to work but, in reality if it doesn't for now, it will be for show until I can gather enough coin to do it right. Another question, where can I get the correct wiper vacuum switch? I see one on ebay but I can't believe it costs $18 to ship. Last question, are vacuum wipers supposed to park and stay up? My wipers drift down to the vertical position as I am driving.
I Have my Old Vac wippers you are welcome if you would like them contact me via P.M.
Posted: Thu Feb 17, 2011 5:40 pm
by Glenn
M37 wipers have the individual switch on the wiper motor.
Posted: Thu Feb 17, 2011 8:58 pm
I don't know of a source for "used" winch parts-best bet is the guys/gals on this forum, or one of the HMV vendors. A regional swap meet would also be a good place to score if you can wait a couple of months when they start gearing up....
Posted: Thu Feb 17, 2011 10:57 pm
by cuz
John at Midwest Military has a lot of winch stuff.
Posted: Fri Feb 18, 2011 8:19 pm
by Cav Trooper
Thanks guys for the winch info. The wipers on my truck don't have any switches, they may be from some other vehicle, Jeep maybe.
