New questions
Posted: Tue Nov 09, 2010 5:30 am
I noticed some play in my steering wheel when I bought my truck and hoped it was just an adjustment. Turns out it's the sector/steering arm bushings that are shot. I see by the manual that I have to remove the steering wheel and take out the entire assembly. No problem with that but, where is the best place to find steering box parts if I need them. I can turn bushings out of amco bronze if I have to and turn the shaft if it's out of round and or scored. If the worm and sector are bad, then I will have to source them. Are there any vendors with those parts or can I buy a new steering assembly? Also, I notice that since I drove my truck last week, the passenger door glass has broken, don't know how but, it's cracked. The glass appears to be laminated safety glass. Other than being a PIA to remove, I presume it is just flat laminated glass that I can have cut at a local glass shop, correct??
Cav Trooper
Cav Trooper
