Page 1 of 2
Transfer case color
Posted: Fri Sep 10, 2010 10:54 am
by Gerry
Was the transfer case from the factory silver like the the engine? Also what color was the shifter controls under the cab?
Re: Transfer case color
Posted: Fri Sep 10, 2010 5:40 pm
by paul
i am not 100% sure but the t-case i believe was black, at least onthe canadian one
Posted: Fri Sep 10, 2010 7:01 pm
by mike_l
I think when this topic was discussed in couple years back, someone said the Chrysler historian said they were silver. From a post by Lifer in 2008: "The engine, transmission, and transfer case would have been a "semi-semi-gloss" silver."
Posted: Sun Sep 12, 2010 7:18 am
by Gerry
Posted: Sun Sep 12, 2010 10:27 am
by Lifer
mike_l wrote:From a post by Lifer in 2008: "The engine, transmission, and transfer case would have been a "semi-semi-gloss" silver."
Thanks, Mike! You saved me the trouble of ferreting it out again.
Posted: Sun Sep 12, 2010 5:56 pm
by Gerry
Lifer.
Do you remember if the shifter rods under the truck should be silver also?
Posted: Mon Sep 13, 2010 4:16 am
by Lifer
I'm not sure on that one! My guess would be black, same as the shift levers and undercarriage, but that's all it would be...a guess.
Posted: Wed Sep 15, 2010 6:32 pm
by Gerry
Thanks lifer. Where the shifters in the cab black or od
Posted: Thu Sep 16, 2010 6:05 am
by Lifer
The shifters in the cab were originally black, but usually got painted to match the body color of the truck shortly after being assigned to a unit (and
definately before the next IG inspection
Posted: Thu Sep 16, 2010 9:21 am
by Gerry
Lifer thanks, I was thinking od but want orig factory.
Posted: Fri Sep 17, 2010 4:14 am
by T. Highway
Lifer wrote:The shifters in the cab were originally black, but usually got painted to match the body color of the truck shortly after being assigned to a unit (and
Thanks Lifer.........I just learned something new today. I was just starting to clean up the shifters for paint and did notice that black was one of the colors under the OD.
Posted: Mon Sep 20, 2010 1:04 pm
by Gerry
Am I right in thinking the drive shafts where black? If so where the flanges on the transfer case and tranny black or silver or on painted?
Posted: Mon Sep 20, 2010 1:22 pm
by Lifer
Yes, the driveshafts were usually black. The transmissions and transfer cases were usually painted as fully assembled units, so their flanges would have been silver to start with. Again, they would have been repainted eventually once they had been in service a while. This usually occurred when it was necessary to remove them for overhaul.
Posted: Mon Sep 20, 2010 1:43 pm
by Gerry
Lifer,
Thanks again
Posted: Fri Sep 24, 2010 8:43 pm
by Josh
It all depends on what period in the life of the truck you want to depict... 80 years from now when Im gone, or have one marble circlingthe drain,some kid will restore mine to 2010 vintage, and he will wonder "hmm, was the Transmission black, or grey?" And only I will know the correct answer...
