Winch roller fairlead
Posted: Mon Aug 16, 2010 9:21 am
by N1VSM
I'm thinking of putting a roller fairlead in front of my LU-4. Thoughts? Suggestions? Experiences?
Re: Winch roller fairlead
Posted: Thu Aug 19, 2010 4:04 pm
by Master Yota
I've never seen a wide enough roller setup to fit the width of the drum. It wouldn't be too difficult to build one though, some heavy wall tubing, machined on the ends to fit a small sealed roller bearing, and some 1.4" plate for mounting brackets. I would use at least a 5/8" bolt to mount the rollers. The length of the top and bottom rollers might pose a challenge inregards to mounting them.
Perhaps, take apart a Warn fairlead (or other) and see how they are built. Copy the design, and just use a longer top and bottom roller. Shouldn't be too much of a challenge.
Show some pic's of what you come up with...
Posted: Sat Aug 21, 2010 9:19 am
We have some assembly's we have used in the past, if you have interest, I can email a photo.
Posted: Sat Aug 28, 2010 7:26 pm
by geraldoM37
If your cable is installed properly ( CABLE COMES OFF BOTTOM OF DRUM) you should not need one, as the bumpers will do the job as designed. When I got my truck the fellow had a fairlead bolted on the bumpers because the cable was ridding up above the winch housing, he had the cable wound wrong on the drum (comming off the top of drum) !! Check how your cable is installed on the drum.
Posted: Sun Aug 29, 2010 5:12 am
by Glenn
geraldoM37 wrote:If your cable is installed properly ( CABLE COMES OFF BOTTOM OF DRUM) you should not need one, as the bumpers will do the job as designed. When I got my truck the fellow had a fairlead bolted on the bumpers because the cable was ridding up above the winch housing, he had the cable wound wrong on the drum (comming off the top of drum) !! Check how your cable is installed on the drum.
Good point, but a fairlead allows for some more angled pulling. Definitely not a desirable situation but sometimes a necessity, sometimes a last resort situation.
