Clearances and pit falls
Posted: Wed Apr 21, 2010 4:27 pm
Well I finally got my 318 mounted, now I start hooking up linkages and things.
The fuel and brake lines that ran inside the DS frame are now within 3" of the exhaust manifold, I plan on shielding these with highly reflective aluminum and probably some insulation. Is this enough or is there a better solution?
I cut away about 3/4" off the top of the frame to fit the exhaust manifold leaving about 3/8" gap for the engine to move. Is this enough?
My bell housing has a lever arm that stuck out to far, it hit into the suspension bolt and old engine mount. A little butchery with the band saw to remove ear off the the old mount and the end of the clutch arm was the quick fix. How much room should I leave between the lever arm and suspension bolt keeping in mind the shorter I go the harder it is to work the clutch?
Or is it best to modify the bell housing to take the original yoke?
Should I install a Y pipe and single exhaust or go duel exhaust?
If I go dual exhaust, how do rout to get past the master cylinder?
Any help or thoughts would be appreciated.
Rich
Rich
