changinf the generator
Posted: Thu Jan 10, 2008 5:02 pm
by gwalker
Does anyone know for sure if the 24v alternator has the same mounting points as the 24v generator? I was thinking it did since the 100 amp gen. also fits a 715 which used the alternator. Was considering converting if it did although Id have to make up some wiring changes as well.
My experience
Posted: Thu Jan 10, 2008 5:51 pm
by N1VSM
I swapped out for a 60A mil. alternator and it fit just perfectly. I did have to change the pulley, but that was a piece of cake.
Posted: Thu Jan 10, 2008 7:05 pm
by M-Thrax
The mounting points are the same but the 3 groove pully off a 100amp won't fit on a 60amp alt ( 100amp has bigger shaft ). now the single 30amp generator pully will fit on a 60amp alt. I had a 100amp setup on my first engine so instead of changing out all the pullys I bought a 60amp alt that had a 3 groove pully but it only matched up to 2 of the 3 grooves on the engine pullies so I only ran 2 belts which you can barly see in the picture ( click below )
http://news.webshots.com/photo/10294263 ... xDvgZROIqs
Posted: Fri Jan 11, 2008 11:41 am
by gwalker
That makes the reg to dash harness obsolete what wires did you have to change to make the alt connections to the truck
