90# gear lube.
Posted: Mon Oct 26, 2009 11:28 am
by Gerry
IS there any special gear lube I need to use in my differentials? Also how much will I need?
Posted: Mon Oct 26, 2009 11:52 am
Nothing special: Regular GL90. You'll find out quickly if your inner seals are bad because the oil will start leaking out.
Posted: Mon Oct 26, 2009 12:03 pm
by Gerry
Thanks Cal Gary
Do you know how much will I need?
Posted: Mon Oct 26, 2009 1:49 pm
by cuz
Each gets 6 pints.
Posted: Mon Oct 26, 2009 2:17 pm
by Gerry
Thanks Cuz,
I am used to your m38 advice. Great to have you here now
Posted: Mon Oct 26, 2009 3:00 pm
80-90 gear lube is a better choice, flows better on a cold start up. Making a premium brand choice is also a smart move. Many cheapo brands are out there now. With bearings to build a diff now over $600, you want to invest in a good quality oil that will do the best job.
Posted: Mon Oct 26, 2009 6:08 pm
by Gerry
Charles,
Any brands you recommend?
Posted: Tue Oct 27, 2009 9:11 am
Gerry wrote:Charles,
My preference would be Royal Purple Synthetic MaxGear, available through NAPA or Synergyn 80-90 gear lube, available from
www.SynergynRacing.com
Hydrotex is a very good brand also.
Any of these have a strong additive package with ingredients that causes the oil to adhere tenaciously to gears and bearings, far superior lubricants to the general off the shelf brands.
Posted: Tue Oct 27, 2009 10:04 am
by Gerry
Charles
Posted: Thu Nov 05, 2009 3:37 pm
by greencom
MSeriesRebuild wrote:Gerry wrote:Charles,
Charles,
I assume that would also be good to use in the gear boxes of my '42 jeep?
Greencom
Posted: Thu Nov 05, 2009 4:08 pm
Good for differential use.
Posted: Thu Nov 05, 2009 4:10 pm
by Captnsim
Great stuff Charles. Thanks
Posted: Fri Nov 06, 2009 10:10 am
by Montanaorbust
I fill mine up with grease.. jk
