Windshield Frame Predicament
Posted: Mon Dec 17, 2007 3:58 pm
In process of strippin' and dippin' the windshield assy. which I took apart last spring. On test re-assy, the windshield assy (the glass hinged assy) attaches to the windshield frame with a number of screws - Problem is while there are holes in the upper part of the windshield frame they are neither threaded or small enough for the pre scribed screws.
While investigating in more detail, the manual exploded view shows only the hinge and the screws to attach the windshield assy to the windshield frame. While looking inside the frame through the screw holes, which are too large, I notice there is a piece of metal that's roughly the length of the windsheild assy floating around in there, likely previously attached with rivets that have long since served there purpose.
So I suspect this floating piece of bar steel (there is one on each side and I don't think they are the same piece of steel) is what the windshield assy screws are SUPPOSED to attach to. Can someone tell me if I'm on the right track, what the solution to my NEW problem is or tell me I'm not on the right track?
Thanks in advance. Finally getting some rain/snow here in californimexico.
