What should temp guage read in Florida??
Posted: Fri Jul 17, 2009 11:58 am
by Tim7750
My M43 has been sneaking up to 220 degrees when running on long trips (20 miles+). The temp here in Florida in the middle of the day has been reaching 96 degrees. I have not overheated, but I was wondering if any of you guys think this is a concern. I have just replaced the water pump and flushed motor and radiator several times and I am not running a thermostat.
Posted: Fri Jul 17, 2009 12:14 pm
by powerwagontim
hi Tim,
I would put the thermostat back in.
Tim
Couple of thoughts
Posted: Sat Jul 18, 2009 5:58 am
by pfrederi
First I agree out the thermostat back in. No thermostat speeds the flow of water...but water going through the radiator too fast doesn't dump its heat as well....
Are you sure your temp gage is accurate??? Try running with out the cap on until she gets warm (not really hot) then use your wife's meat thermometer in the radiator and compare to your gage reading. Then return the thermometer before she finds out!!!
Re: Couple of thoughts
Posted: Sat Jul 18, 2009 10:16 am
by Lifer
pfrederi wrote:First I agree out the thermostat back in.
Good advice.
Great advice!
Out-freakin'-standing advice!
Posted: Sat Jul 18, 2009 8:44 pm
by greencom
I've heard accounts of the water distribution tube in the block clogging up and causing overheating. Who knows?
Greencom
Posted: Sun Jul 19, 2009 3:54 am
by knattrass
The cooling tube is an accident waiting to happen, especially when the trucks were run on straight water, we were amazed at the amount of rust that came out of ours. We had pulled our engine so it was easy to work on.
Posted: Sat Sep 19, 2009 5:12 pm
by Sal
I hope you fellows don't mind me putting my 2 cents in but you might be interested to see what I found when I replaced the water pump and pulled the water distribution tube. I found the last two openings clogged.
Posted: Sun Sep 20, 2009 6:58 pm
by Chunk
When its been 108 degrees in Nevada,my M37 always read 180 degrees.
