1/8 " wire next to break reservoir
Posted: Sun Dec 09, 2007 4:28 pm
by anthony manzella
What is this wire that is connected to what i think is the break peddle notice it moved when i was bleeding the breaks it has a hook at the back side of it but does not look like it is hook to a dam thing it runs along side of the break reservoir on the right side of it. is it a return for the break peddle minus a spring if so i don't see where a spring whould be or a hole to put it in on the frame rail
Wire.
Posted: Sun Dec 09, 2007 4:39 pm
by Nickathome
Its probably the wire that connects to the brake light switch. Pressure from applying the brake pedal somehow activates this switch to turn on the brake lights.
Posted: Sun Dec 09, 2007 5:21 pm
by monkeybone
i believe you're talking about the return spring extension ,it attaches to the spring rear of the master cylinder and then to a bracket just rear of where the brake line goes thru the frame
1/8" wire- breaks
Posted: Sun Dec 09, 2007 6:47 pm
by anthony manzella
tank's for some heads up will look at both possibilities when I install my speedo cable later in the week . HAPPY HOLIDAYS TO ALL.
