drive shaft u-joints
Posted: Sat Jun 20, 2009 3:51 pm
is there a napa part# for them? if not where can i get them.
Both size M37 u-joints are available from NAPA. The # escapes me at present, can check tomorrow at the shop, or you can take a joint in & match it up easily. NAPA has an on the shelf Chinese joint line now, the older Presision brand joints are still available too as an overnight. I recommend the Precision joints.bubba_got_you wrote:is there a napa part# for them? if not where can i get them.
thanks. im not in a hurry to get them (probably go Wednesday) and i probably will get the Precision joints ( i have gotten the napa cheep car* before and it has worked.......for a day.MSeriesRebuild wrote:Both size M37 u-joints are available from NAPA. The # escapes me at present, can check tomorrow at the shop, or you can take a joint in & match it up easily. NAPA has an on the shelf Chinese joint line now, the older Presision brand joints are still available too as an overnight. I recommend the Precision joints.bubba_got_you wrote:is there a napa part# for them? if not where can i get them.
