Steering knuckle
Posted: Fri May 15, 2009 5:34 pm
Today while working on the brakes I noticed that the right side top cover doesn't have a Zerks fitting as the drivers side has? Should I add one?
There should be a fitting in both top covers, someone likely replaced a top cover using one from the bottom.Wayne64 wrote:Today while working on the brakes I noticed that the right side top cover doesn't have a Zerks fitting as the drivers side has? Should I add one?
