Frame color
Posted: Wed May 13, 2009 9:06 am
by Gerry
Before I buy my paint I just want to varify the frame was semi-gloss black from the factory.
Posted: Wed May 13, 2009 10:23 am
by Carter
The frame of my truck was semi-gloss black with no primer under it, just black, some of which peeled off easily when I water blasted it in prep. for sand blasting, exposing unrusted bright steel which rusted red overnight. The black in this pic is the orig. paint and the red is the surface rust which formed on the exposed frame steel.
Posted: Wed May 13, 2009 2:56 pm
by refit1701
Mine has a mixture of blue, black and green. Mostly due to paint jobs over the years.
They came black and when the GI's repainted them at the motor pool, they became overall OD or Blue.
Posted: Wed May 13, 2009 7:03 pm
by powerwagontim
My 52 Air Force truck frame was Strata Blue with red oxide primer. The replacement frame I am using was OD, with red oxide primer underneath.
No black on either one.
Tim
Posted: Thu May 14, 2009 1:05 pm
by Gerry
Thanks all for the info
Gerry
Frame Color
Posted: Thu May 14, 2009 1:15 pm
by m-37Bruce
Mine is gloss black under several shades of od , one silver one red & one orange. Topped off with another coat of rattle can od. :oops:
Posted: Fri May 15, 2009 3:36 am
by Lifer
All frames were painted "chassis black" at the factory. This was a hard-finish, baked-on semi-gloss enamel. The frames were dipped in an acid bath, allowed to dry, and the etched metal was then painted without primer.
What happened after they left the factory (and when it happened) is anybody's guess.
