pin hole in oil pan
Posted: Sun Apr 05, 2009 12:02 pm
would I be better getting it welded or should some liquid steel work fine.
Brazing the hole shut will do a neater job, welding can leave thin areas around the repair which can cause issues down the road.Gerry wrote:I have pan off and sand blasted(black beauty). Just the one hole the rest looks solid.
I don't agree with this re; welding. If a pinhole, drill it out to about 1/4 in, then plug weld it with a copper paddle behind the hole. Grind flat and you'll never see that hole again. Lay on some good paint and your done. No worries about thin spots, unless youre welding leaves something to be desired.MSeriesRebuild wrote:Brazing the hole shut will do a neater job, welding can leave thin areas around the repair which can cause issues down the road.Gerry wrote:I have pan off and sand blasted(black beauty). Just the one hole the rest looks solid.
