Upper/Lower/one piece exhaust pipe
Posted: Mon Mar 02, 2009 1:14 pm
by refit1701
I need to buy the lower exhaust pipe. I have seen a "one piece" pipe advertised by our friendly vendors....is this a replacement for the upper/lower pipe that was original? Is there any advantage to it?
I'm only missing the lower pipe and a couple of gaskets to complete the exhaust system.
I Think
Posted: Mon Mar 02, 2009 2:01 pm
by m-37Bruce
To my re-collection, there are 4 pc's The first at the manifold that has the swivel nut/bolt, the next pc. goes to the muffler, it has a ninety and a little kink in it, then a short straight pc, w/ another ninety to the tip, I think that's right, four plus the muffler?
My manual is in the shop w/ the od godess.
Posted: Mon Mar 02, 2009 5:17 pm
by refit1701
That's correct, Bruce. But I have seen a "one piece" pipe advertised for $80 and was wondering if it replaced the first two sections ahead of the muffler.
Did the 37 use the tip extension as well as the 43?
Both Ways
Posted: Mon Mar 02, 2009 5:47 pm
by m-37Bruce
The price sounds right, I think that is how that particular piece of pipe is available. I got mine from John @ Mid-West.
The tip itself is only about 8 inches.
Pipe...
Posted: Tue Mar 03, 2009 3:29 am
by Nickathome
refit1701 wrote:That's correct, Bruce. But I have seen a "one piece" pipe advertised for $80 and was wondering if it replaced the first two sections ahead of the muffler.
Yes, that is correct. The one piece pipe is a direct replacement for the two piece exhaust pipes ahead of the muffler. I also got mine from Mid west Mil.
Posted: Tue Mar 03, 2009 4:39 am
by refit1701
Great. I'll have to pick one up then. My wife and kids will appreciate not hearing the loud engine noise in the garage!
Posted: Tue Mar 03, 2009 6:51 am
I've seen several that run w/o the short exhaust tip, in order to save time whenever they mount the fording exhaust pipe.
Posted: Tue Mar 03, 2009 6:56 am
by refit1701
Cal_Gary wrote:I've seen several that run w/o the short exhaust tip, in order to save time whenever they mount the fording exhaust pipe.
This probably explains why I haven't seen many trucks with the tip installed. Most guys want that fording kit.
