inner axle seals
Posted: Sat Jan 10, 2009 12:58 pm
by vinkon3775
to change my inner axle seals in my front axle do i have to drive the seal from the inside out to remove? i noticed when i removed the axle shaft that the seal was behind a brass bushing out towards the end of the axle tube.
Posted: Sat Jan 10, 2009 1:27 pm
by sbaumgartner
You are going to need a slide hammer with a finger-hook type attachment. That's what I used anyway and it made the job really easy. --Steve
inner axle seals
Posted: Sat Jan 10, 2009 2:26 pm
by vinkon3775
so even with the bushing in front of it the slide hammer did the job? i'll have to buy or borrow a slide hammer then. i was going to fit sections of pipe from one side to the other. your way sounds easier!
Posted: Sat Jan 10, 2009 2:56 pm
by sbaumgartner
Yeah, you just have to work your way around the circumference of the seal, sliding the hammer a few times in each spot, but they popped out pretty quick. I just rented one for the day for $15.
Posted: Sat Jan 10, 2009 3:51 pm
Slide hammer is the key, but a better option is with a 2 jaw expandable puller attachment instead of the finger type. Some of these seals & bushings are really tight. The expandable jaw type prevents slip offs & really is easier to use for this job, especially since you are pulling bushings & seals in the same operation.
inner axle seals
Posted: Sat Jan 10, 2009 4:58 pm
by vinkon3775
thanks for the tips guys. this will give me something to do monday!
