Dash Spider Harness
Posted: Fri Jan 02, 2009 3:50 am
I worked on my dash panel this past weekend. I know that the spider harness (wires #27) are the feeds for the gauges. Yes? The long lead with the Douglas connector and the "L" shaped metal bracket has me confused, It goes where? I don't see it's source on the wiring diagram. I also have no continuity from this wire to the other end of the Douglas connector at the bracket?
There is a connector inside the Douglas shell but the terminal does not seem to make contact inside the plastic connector? The same goes for my old one when I tested it. Where does this bracket mount? Is this the hot feed for the spider harness? As my truck had little or no of the original wiring when I got it, I may be posting many wiring dilemmas as this in the future
