Another wiper related ?
Posted: Sun Dec 21, 2008 11:41 am
by Nickathome
Will be installing my electric wipers within the next day or two. Am wondering, can I run one hot wire and splice the two motors together, or do I need to run two separate hot wires from the power source?
Posted: Sun Dec 21, 2008 1:42 pm
by Carter
As long as you use a heavy enough wire to handle the load, one will do.
Posted: Sun Dec 21, 2008 1:51 pm
by knattrass
We used 12 gauge single wire to the left and daisy loop a wire to the right. We found that the left runs a little quicker than the right given the load drop. We used a push/pull on/off switch on the i/p to provide power. Many times Zach only turns the driver's on so it wasn't a big deal. I guess doing it over, I'd pull 2 load wires.
Wiring...
Posted: Sun Dec 21, 2008 3:22 pm
by Nickathome
Somebody here told me to use 14 gauge, and that's what I bought. I don't plan to install any switches, will just use the switch on the back of each motor, and will probably just use one motor at a time.
What's a daisy loop?
Posted: Sun Dec 21, 2008 4:57 pm
by jbxx
Going from one connection to the next with a single feed.
What is the amperage load of a wiper with resistance put on the arm.
eg snow/ ice/ a hand etc.
14 ga. should be OK though.
J.B.
Wipers
Posted: Sun Dec 21, 2008 6:33 pm
by Nickathome
jbxx wrote:Going from one connection to the next with a single feed.
J.B.
If you're asking me what the amperage is, my answer is I haven't a clue.....
