engine swap
Posted: Wed Dec 03, 2008 7:25 am
by vinkon3775
Has anybody tried swapping aford smallblock complete with np435 grannytranny into the m37? My stock 230 is getting pretty weak and i'm trying to decide what direction to go in. I ask about the ford setup because i have more access to ford used parts. I have pretty good fabrication skills so that's not a problem.
Posted: Wed Dec 03, 2008 8:05 am
by k8icu
I would think that is a 318 chysler fits into the M37 and the 4BT cummins can fit then I would think a 351 Cleveland or what was the smaller one the 308? would fit with out too much fuss. You biggest thing will be the length from the output of the transmission to the transfer case. I would think that you will need to do some messuring before you pull the old engine and trans and install the new. Anything an be made to fit if you have enough time and money....but I would think if you have good fabrication skills and the right tools I would think it would be a straight forward instulation.
Posted: Wed Dec 03, 2008 6:09 pm
by Tom @ Snake River
As long as you were doing a swap, I would sure consider dropping in a setup with a married transfer.
That is the one thing I hated was trying to couple up to the existing transfer case.
engine swap
Posted: Thu Dec 04, 2008 5:04 am
by vinkon3775
Thank's for the opinions guys. one thing about a married transfer case, won't the rear driveline angle be a problem?
Posted: Thu Dec 04, 2008 7:26 am
I believe they make mating adaptors that allow you to rotate the case so you don't have those extreme shaft angles-I saw this on "Trucks" a while back.
engine swap
Posted: Thu Dec 04, 2008 10:35 am
by vinkon3775
thanks for the input. i'll have to look into the married transfer case idea.
Posted: Wed Dec 10, 2008 7:09 am
by bubba_got_you
I had a dodge dump truck transmission on my 318 and I didn’t change it to the m37 transmission and the only problem I ran in to was mating the tranny to the t-case. Simply because the transmission used a spline that was made to join at the u-joint and not bolt together, But the tranny spline was built to have an e-brake so all I did was cut the u-bolt part off so it only had the flat part where the e-break bolted on. So I welded up the original holes and drilled new ones and it works fine.
The point behind what I am saying is that it can be done and you should try to keep the original np200 t-case simply because it is the best t-case you can get for under $1000.
I know this because I live in Florida (the mud truck state) and I have seen people pay as much as $800 for a np200 to put in there mud trucks where as you cant give the others away.
Just my thoughts,
Trevor
engine swap
Posted: Wed Dec 10, 2008 9:24 am
by vinkon3775
the original plan was to use uglytruckling's kit to swap in a 318 and keep the original tranny. i'm leaning towards the ford small block/435 tranny just to keep it simple in terms of being able to mate the tranny to the engine. it's kinda hard to find good used dodge parts around here, hence the idea to go all ford. plus they're not making the adapter kit any more. i know in past experiences that the 435 is a pretty good tranny.thank's for the suggestion though and i do appreciate your input.
Re: engine swap
Posted: Thu Dec 11, 2008 7:24 pm
by k8icu
vinkon3775 wrote: hence the idea to go all ford.
Is that leagel?...
I think some pureist will have problems with ford parts in a dodge... lol.
I'm just yanking the old chain there....It sounds like a good idea since I believe you said you have the ford engine and trans already so that will keep the cost down. You may have some issues with maiting the trans to the drive shaft of to the transfer case unless you are going to swap in a bolt on transfer case like a NP208 maybe. Problem with ford transfer cases is that they front output on the drivers side where as the dodge is on the passinger side. Just something to keep in mind.
engine swap
Posted: Sat Dec 13, 2008 8:03 am
by vinkon3775
luckily i still have some time left to make a decision. heck i'd even consider chevy parts if they seem to work better. idealy a deisel swap would be best, but i'm looking at money limitations and i'm more familiar with gasoline engines. and your right, i'm not a purist. i want to leave the look of the truck but update it a little.
