Proper instrument panel for b1 series M37s?
Posted: Thu Oct 02, 2008 8:18 am
by Nickathome
Is the B1 model of M37 supposed to have the dash panel with the little screw in red instrument light lenses or did they come with the other style with the more involved lighting? I seem to recall seeing a panel for an M151 and it curiously looked exactly like the one in my truck, or were they all interchangeable?
Posted: Thu Oct 02, 2008 8:34 am
by Carter
The B1 series and the 151s used the same dash lights and instruments (same stock numbers) however, I don't know if the panels interchange.
Posted: Thu Oct 02, 2008 5:50 pm
by k8icu
I do not believe that the panels themselves are interchange able the M37 is a larger opening, but the gauges and lights are.
Panel
Posted: Fri Oct 03, 2008 2:14 am
by Nickathome
10-4, thanks guys.
Posted: Fri Oct 03, 2008 6:09 pm
by gwalker
The dash panels should interchange w/ all jeeps an trucks under a duece it is a standard, the duces and larger had more gauges an so a larger panel. Other than that the diff is that they went from the metal douglas connectors to the rubber packard type wire connectors, the dash light assy changed at that time also.
